Can 8.2 built exe run in 8.6 environment
Thanks.
Message 1 of 9
(3,460 Views)
An exe built with 8.2 will run with the 8.2 runtime engine. I have no idea what you mean by 8.6 environment.
Message 2 of 9
(3,452 Views)
Can exe built with 8.2 run with the 8.6 runtime engine or development environment?
Message 3 of 9
(3,442 Views)
All exe's require a matching runtime engine. You cannot mix and match.
Message 4 of 9
(3,422 Views)
If you do not have the LV8.2 Run-Time engine, it can be downloaded from this website.
Message 5 of 9
(3,412 Views)
But I tried, seem can do it.
Message 6 of 9
(3,398 Views)
Are you saying you can do it?  Did you just figure that out?  I'm not sure I understand what you are trying to do.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 7 of 9
(3,395 Views)
If you have an exe built with 8.2 and it runs, then you have the 8.2 runtime installed. Just look and see what runtimes you have. They are all listed in MAX.
Message 8 of 9
(3,386 Views)
Accepted by topic author alex.
When you installed LabVIEW, it probably installed run-time engines to support other versions as well.  As Dennis mentionned, check under software in MAX for a list all all run-time engines that are installed.  For instance I have a listing that includes LV6.1 although I have never installed that version on this PC.
R
Message 9 of 9
(3,367 Views)
