Camera resolution limited to 352x288 in MAX
I'm using an USB Camera with Directshow in Measurement & Automation Explorer.
The camera is able to acquire with a resolution of 2592x1944, but in MAX in (Acquisition Attributes tab), the max. resolution available is 352x288.
I've succeeded to acquire images with a resolution of 2592x1944 with the software provided by the manufacturer.
So how can I set the resolution to 2592x1944 in MAX ?
Thanks in advance,
Maugan.
Message 1 of 9
(3,655 Views)
Can you share the screenshot of MAX or your LabVIEW code (if you have any) here, to understand the issue.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 9
(3,645 Views)
I have set up the manfacturer's directshow driver which gives me the window of the first screenshot, with a resolution of 2592x1944.
Then I want to configure the acquisition attributes in NI MAX, and I get the two other screens, with a max. resolution of 352x288.
Message 3 of 9
(3,633 Views)
please check this discussion, and let us know if this helps.
Message 4 of 9
(3,624 Views)
I've tried to use IMAQdx in LabVIEW, with the "Grab and Attributes Setup" VI, but it doesn't change anything : I can't set the width/height of the camera et the video mode proposed are the same that in MAX (cf attachments).
Any other solution ?
I think it could be the configuration of the directshow driver, but I can't find any way to modify it.
Message 5 of 9
(3,594 Views)
One more link I found (but I think you might have seen it already):
Troubleshooting USB 2.0 (DirectShow) Camera Installation Problems
Message 6 of 9
(3,587 Views)
Yes, I've already seen it, but it doesn't help me more.
Other idea ?
Message 7 of 9
(3,584 Views)
According to the camera's manufacturer, it could be their directshow driver which does not support a better resolution, but they doubt a little.
Maybe other ideas ?
Message 8 of 9
(3,561 Views)
Is there anybody who has succeeded to acquire an image, with a USB Camera, with a resolution over 352x288 ?
Because it could be a problem from ni softs.
Message 9 of 9
(3,542 Views)
