Camera not selectable in "Session in"
I have the following setup:
An "ELIIXA+ 8k/4k" camera, connected to a PXIe-1435 module in the PXIe-1082.
My goal is to programmatically aquire images from within LabView (14.0.1 / 32bit)
Within MAX, I can snap pictures just fine.
I wrote a simple program to run on the PXI, but i can't select the camera as "cam0" (or anything) in the "Session in"-selector.
(Yes, I did deploy the VI to the PXI)
This is a screenshot of MAX (german version)
Why does the camera show up as "Channel 0", as opposed to "cam0"?
Can I change that?
How do I use a camera that shows up as "Channel 0" in LabView?
This is my test VI, it displays the error code "-1074360311 IMAQdx Open Camera", as is expected, when the camera is not properly selected.
There seems to be something fundamental that I am completely missing.
Thank you for your help.
(3,358 Views)
Accepted by topic author SeWi
Hi SeWi,
since you have a camera link camera you should yous the IMAQ driver not the IMAQdx.
What Is the Difference Between NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O? - National Instruments
http://digital.ni.com/public.nsf/allkb/0564022DAFF513D2862579490057D42E?OpenDocument
(3,310 Views)
