Calling dll function that has struct that consist of union as input parameter
Version:1.0 StartHTML:000000235 EndHTML:000002791 StartFragment:000001962 EndFragment:000002759 StartSelection:000001962 EndSelection:000002759 SourceURL:https://forums.ni.com/t5/forums/editpage/board-id/170/message-id/1095110
I have function "myFunction" in dll that is defined like this:
DLL_EXPORT unsigned long myFunction(void * pHandle, myComplexParameter configuration);
myComplexParameter is struct that is defined in another .h file and it is defined as:
struct myComplexParameter
  myCommunicationCode communication_code;      // This is struct
  myConfig config_code;    // This is struct
myConfig is another struct that is defined in the sam .h file as:
struct myConfig
	MA_Frequency ma_clock; // union
So MA_Frequency is:
union MA_Frequency
	uint32_t frequency_hz;								enum frequency;
Is it possible to call this function from labview using call library function node? How can C++ dll code be redefined to be used in labview?
(2,851 Views)
It's not easily visible as I thought at first that your union only consists of one element which would be pretty useless. But in C an union is as large as the largest block inside the union is, so unless you have a very strange C compiler that does something pretty unexpected for enums, the union is in fact simply the size of the uint32_t. The enum is occupying the same memory location as the uint32_t.
In respect to your last question, please explain in more detail. It's not clear what you are asking.
Rolf Kalbermatter  My Blog
(2,822 Views)
If this question refers to how to call a C++ class from LabVIEW through the Call Library Node the answer is to write a wrapper DLL in C++, which must export standard C functions for every class method you want to call and in additiona to that a constructor and destructor function.
Take a look at this recently reactivated LabVIEW Wiki page which explains the principle.
The canonical start page for this is: https://labviewwiki.org/
(2,809 Views)
