Calling a LabView DLL from VB
I am running an NI example which is here
http://zone.ni.com/devzone/cda/epd/p/id/3990
and when I run it the new VB environment converts the program to the new .net structure ok.
However, when it runs it gives this error
Loader lock was detected
Attempting managed execution inside OS Loader lock. Do not attempt to run managed code inside a DllMain or image initialization function since doing so can cause the application to hang.
Any ideas?
(2,915 Views)
Hi tomnz,
Is this the error you are seeing?
'C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\7.0\DNCompInfo.dll' is attempting managed execution inside OS Loader lock. Do not attempt to run managed code inside a DllMain or image initialization function since doing so can cause the application to hang.'
National Instruments has a KnowledgeBase article that discusses this issue. Please give this a try. If you still receive this error, please let me know.
Donovan
(2,879 Views)
