Calling a C program in Labview
As noted, you can compile the C code into a DLL and call it from LabVIEW. The LabVIEW Help tells you how to do this, as noted in previous replies to this thread (see message #4).
Naqqash wrote:
I don't think I will be able to make that CRC code which is in C in LabVIEW
What makes you say that? Have you looked at the CRC examples that have been posted? Did you try a search?
Message 11 of 12
(1,053 Views)
Thank you very much. Now I've got the idea. Yep I didn't tried to think that I should check about CRC directly, I was not sure actually that's why I've posted the whole problem.
Naqqash
Naqqash
Message 12 of 12
(1,050 Views)
