Calling a C/C++ dll from LabView (dll has pointers)
I'm new to LabView and was wondering if anyone could help me out or point me to a tutorial on how to pass a LabVIEW cluster to a dll.
my dll has the following struct and i'm trying to populate this in LV, so I've created a LabVIEW cluster that I plan on passing to the DLL so that the DLL can then populate it....
I'm using the Call Library Function Node in LabVIEW to call the "get_board_info" function that is in my dll  (extern "C" short CCONV acq_get_board_info(short count, myStruct_board_info *info);
here is the struct from the dll:
MyStruct_board_info
char name[32];
short type;
short irq;
char en_first_gain;
long first_gain_max;
char computer_ctrl;
char pad[3];
the dll also returns an error code of either "success"
I'm not real sure how to pass the LV cluster to the dll
(2,758 Views)
chadklunk-
Below are a few links to KBs providing information on achieving this.
AE KB 43GBTHSN: Passing an Array of Clusters From LabVIEW to a DLL
AE KB 38LB2BVM: How Do I Pass a NULL Pointer to a DLL?
There is also a DevZone that may also help as well and provides an example.  This example was written in LV 5.0.  So it can only be open in LV from 5.0 - 8.2.  However, if you save it in LV 8.2, you will be able to open it in 8.6.
Using Structures in a DLL with Clusters in LabVIEW
This KB could be helpful for troublshooting.
AE KB 1GRBRNU0: Cannot Access the Members of a Cluster Passed to a Shared Library (DLL)
Take a look at these documents and see if they provide you with enough information.
Mike S
NI AE
(2,732 Views)
