Calling SubVI's recursively !
Hello Everyone,
I'm trying to write a program which should have 5 panels; Main panel, Sub-main, Setting panel, and two Sub-panels. From the main panel, I should be able to call the sub-main and setting panels. Once I am in the sub-main panel I should be also able to go to the other sub-panels recusively. The problem is when I call one of the sub-panels, and try to go back to the Sub-main panel, it goes to the Main panel, instead, and stuck there because the sub-main is still running!
For calling the subVI I'm using a "case sturcture" inside wich I put the SubVI and set the "SubVI node Setup" to:
"Show Front Panel when Called"
I feel my explanation is a bit cofusing Smiley Indifferent, but hope some one can give me some hints to solve this problem.
Cheers !
Mike
(2,846 Views)
To get an answer here, you should include a minimum example VI showing what you are doing.
You have to make any VI's that you try to call from more than one location Reentrant. Hit Ctrl + I (VI Properties) go to the Execution Category and hook off "Reentrant Execution". If you don't., you will have a deadlock if the VI is called from two or more places at the same time.
Geir Ove
(2,816 Views)
Hi Mike,
Geir is correct, and if you follow this link, you should find the steps needed to find your solution.
Thanks and good luck!
reggier
(2,771 Views)
