Calling .NET assembly blocks execution
This looks pretty much like what Yamaeda described to you.  If this works, then you should give him credit for the solution to your question.
Message 11 of 13
(845 Views)
The reason I selected my reply as solution is because I attached VI that help demonstrate what Yamaeda suggested. Often, users jump to the solution and I thought my reply could provide both recognition for who gave the final solution as well as example to implement it.
I specifically quoted him/her  ("I made the two VIs attached to demonstrate the solution proposed above. ") to provide credit.
I now see that you can select multiple messages as solutions, therefore I tagged his reply too.
Message 12 of 13
(817 Views)
You can make it slightly easier by using a fixed VI ref and use the path property of it when you open the ref, that way it's automatically linked if you compile it.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(804 Views)
