Calling .NET Assemblies From LabVIEW
I am developing an application in the LabVIEW and everything is going as planeed so far 🙂
We recently bought an IR sensor from the irisys company and it provides us with .NET and Java API. I need to use the API to connect to the sensor and get/set data. Due to the fact that LabVIEW suports calling .NET assemblies, I decided to use the .NET APIs. The problem is that when I try to run the program in labVIEW, the whole labVIEW freezes! I do not know what the problem is. Is it beause of the API or because of the labVIEW itself. I used MS visual studio to check the code, and found no exeption or odd behaviour!
I have attached my vi and this is the .NET API which I am using (link). I will appreciate if you give me hint.
(3,673 Views)
(3,666 Views)
Thank you nyc for the link. But I think I used the correct blocks. I do not know what is the real problem (its from the labview or from .net API).
I have attached the C# code whitch is provided by the vendor. In the main method we have:
BlackfinEngine engine = new BlackfinEngine();
engine.StartEngine();
and I tried to implement it in labview using the .net blocks (the vi that I attached to my first post), but labview freezes and I should close the labview process from the task manager.
(3,626 Views)
Could it be that your .Net assembly is using .Net 4.x? See here for more info to this and how to do a workaround if this is your problem.
Rolf Kalbermatter  My Blog
(3,621 Views)
Yes, According to the documentation we should install .Net 4.x. I followed the instructions in the link you provided, and create a config file near labview.exe in C:\Program Files\National Instruments\LabVIEW 2011\LabVIEW.exe. but the freezing happened again.
The vendor also provides us other APIs (WinAPI, JavaAPI, LinuxAPI). can I check other APIs in the labview? does labview have a mechanism to inherently support WinAPI or JavaAPI?
(3,619 Views)
JavaAPI would seem unneccessarily involved. WinAPI most likely means DLL function exports which you can call with the Call Library Node, but some basic C knowledge about datatypes and such is definitely a huge advantage when going this road.
(3,616 Views)
