Calling LabVIEW using Matlab active x function.
The data is transfered to LabVIEW but the VI doesn't compute the answer. I've already indicated that the VI run once opened but the VI doesn't compute the answer once the data has been transfered.
(2,868 Views)
Please check out the following link which is an example of the functions in Matlab that need to be called in order to send and retrieve data from LabVIEW. In particular, note that it is using "vi.run=1;" to run the vi.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DF7356A4E034080020E74861&p_node=DZ52053&p_source=External
Ankita A.
(2,868 Views)
