Calling LabVIEW VI's on Remote System
I am trying to call a remote vi's present in PXI RT Controller from my host pc using teststand using Specify Module->Advanced Tab options. I have placed all the vi's on the RT system which i am calling from the remote system. Whereas as when i run my teststand sequence from the host pc it gives a error telling "Model entry point single point could not be exected" sometimes.
I have gone the manual "using labview with teststand" appendix A calling labview VI's on Remote Systems. The VI which i am trying to call from Remote Sytem is an which invokes the hardware like Initilizing,Self Test and close the instument handle,it calls many other sub vi's on the remote system.
It gives many errors when i try to run my sequence on my host, i am not able to understand what may be the problem.
I am attaching list of errors i have faced while execution of my sequence.
Kindly help me out in this regard.
Thanks in advance.
-Anil
Anil-B'lore
(3,077 Views)
Hello Anil,
It looks like this question is being addressed on a different location on the discussion form. Therefore, see the following link for more information on this issue.
http://forums.ni.com/ni/board/message?board.id=330&message.id=5415#M5415
Kevin Leonard
(3,020 Views)
Hi Kevin,
Thanks for your reply, Ya by mistake i have posted in LabVIEW forum later i posted to TestStand.
-Anil
Anil-B'lore
(3,015 Views)
