Calling ActiveX function
I am using an ActiveX function that has following format (in C++)
HRESULT GetLuminanceImage([in] long aMax,
[out,size_is(aMax)] float fBuffer[],
[out, retval]short *sRet);
How can I call this function in labview.
I need to know how to define the parmaters in Call library function node in Labview
Thanks in advance.
-SK
Message Edited by CKSlv on 01-20-2006 03:11 PM
(3,377 Views)
Ah, you don't want to use the Call Library Node, because it isn't a C function. Instead, use the ActiveX pallette with Automation Open, Invoke Node, Property Node, etc.
Note that to use these calls, your ActiveX class must have a TypeLibrary. However, since your snippet is of IDL, I don't think that will be a problem. Also, all the data marshalling will be handled for you automatically by LabVIEW as long as you stay within the OLE Automation types, which again you have.
(3,355 Views)
Hi Lycangeek ,
I got stuck in the same kind of problem , I am using Automation open to load my COM library.
My Com dll is having an exposed function like
CAN_Write([in]long ID,[in] long DLC, [in,size_is(DLC) unsigned char* Data,[out,retval]long *pRetStat);
But when i am calling this function using automation invoke node in labview the Data is not a pointer reference its just accepting unsigned char Data . Can you please let me know how shall i pass the data to this array?? Or shall i need to change my DLL function...
Thanks in Advance.
(3,097 Views)
