Call a Sub VI from Main Vi
As title, I have a lot of sub vi in a main vi, is there any method I can call one of them through sub vi's name?
Currently I am using test cases to define all the sub vi's name, i think that is too troublesome for my sustaining job in future.
Thanks.
(2,495 Views)
Accepted by topic author TanTan
You can use "Call by Reference" under the application palette.
It's not entirely clear what you mean by "using test cases" and "troublesome for my sustaining job".  Without the benefit of seeing the code you haven't posted, I believe you are probably going to make things more complicated than they need to be.
(2,491 Views)
The call reference is the function that I want, thank you!
(2,479 Views)
