Call a SQL stored procedure using input and output parameters
There must be an easy way to call a stored procedure using input and output variables, but I am having no luck.
For debug, I wrote a simple stored procedure (MS SQL Server), which as follows:
CREATE PROCEDURE sp_test_procedure
@ser_num varchar(50),
@new_ser_num varchar(50) OUTPUT
AS
SET @new_ser_num = @ser_num + ' <<<--- This Is Your Serial Number'
RETURN
GO
I am using LabVIEW 6.02, and the database connectivity toolset (ADO.
All the items found on NI's site seem to relate to a) the older SQL toolkit, or b) a stored procedure that returns a recordset.
(3,403 Views)
I found an answer from someone on info-labview, which is as follows:
(in the stored procedure)
Before the RETURN Function, write: SELECT @parameterName (in your case:
Select @new_ser_num )
So the new stored procedure would be:
AS
Number'
Select @new_ser_num
RETURN
GO
(3,403 Views)
just a way to save a few lines of code
@ser_num VARCHAR(50)
AS
SELECT @ser_num + ' <<<--- This Is Your Serial Number'
AS Variable_name
GO
the Variable_name acts like a colum name
(and should be without an '@')
(3,403 Views)
