Call MessageBox() in LV
I want to use Windows API "messageBox()" instead of LV's dialog box by calling the DLL, but how to specify the first parameter of the function :HWND ? How to set the ICON's parameter ?
David
(3,328 Views)
What version of LV do you use?
I could post you a llb where I call this function for LV7.0.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,323 Views)
Why don't you try this?
Also, note that at the top of the page you can see the hierarchy of pages where you can find a lot more information on calling DLLs.
___________________
Try to take over the world!
(3,322 Views)
But how to specify the owner window ? I want to make a model dialog .
(3,304 Views)
Try this...
The second call library node calls "FindWindowA", which is also located in user32.dll.
Hope it helps.
Thomas
Message Edited by becktho on 02-01-2006 07:11 AM
Using LV8.0
(3,300 Views)
