Call Library node and multiple array copies
Ah, I think I see what is going on now.  Initializing an array with a const number is like declaring something in C as a const; it can't be modified unless copied.  As long as the array is declared with a variable instead of a constant, array copying won't occur, unless there is a branch, in which case Labview must copy to prevent memory conflicts.  This helps out a lot.
Austin McElroy
Message 11 of 11
(457 Views)
