Call Library Function returning a pointer to doubles
Say, I have a DLL which exports function
int getdata(int numdatapoints, double * data)
I would like to use a Call Library function to call getdata and getting the
data (* data) into a Labview array of type double. Is this supported by the
Call Library function, or do I have to use a CIN function?
Michael
(3,233 Views)
In the meantime I found out, that you can specifiy a parameter as Array with
format Array Data Pointer and additionally defining the Dimension. But what
do you do when the dimension changes from one call to the other. Is there a
way to define the Dimension dynamically during the execution of the VI
containing the Library Call function?
Michael
Michael Vetsch wrote in message <8lugo2$2q9$4@news.mathworks.com>...
>Hi,
>Thanks,
>Michael
(3,233 Views)
Problem solved. I found an application note on NI's Web page. I've got it
working.
Michael
>Hi,
>Thanks,
>Michael
(3,230 Views)
