Call Library Function Node code error 12
We have been using labview in our lab calling .dll functions from spinAPI
Recently, we are getting the following error "Call Library Function Node code error 12"
we updated the version of the driver that is been called from the vi but we are still getting the same error.
I have tried changing the name of the path, and also including only the name of the dll instead of the complete path but nothing seems to be working.
I am attaching the vi and the folder that contains the driver (spinapi64.dll)
Hope you can help me!
Laura M.
(5,428 Views)
Did you see this page?
It implies that the file you're referencing isn't even a DLL.
Is there a chance you're trying to use a 64-bit DLL from 32-bit LabVIEW?  Or the reverse?  Or trying to use a call library node to open a .NET DLL?
(5,408 Views)
Accepted by topic author LauraCMS
Yes, the problem was I didn't install the driver correctly.
Had to take my PCI card out.
And also the incompatibility issue.
(5,403 Views)
