Calibrating a microphone using SVL Calibrate Microphone
Hi all,
So I'm working on a VI that dislays sound pressure level.
From the other discussions,  it says that SPL can't be measured unless you have a calibrated microphone and a known amplification path.
So basically LabVIEW has this SVL Calibrate Microphone (DAQmx) to calibrate the mic. However, I tried to use it but I've got no result.
I have an ECM 8000 condenser microphone and I'm using a USB-6215 DAQ.
How do I perform this calibration?
(4,733 Views)
First, what do you mean that you "got no result"? No output from the mic? incorrect results?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,711 Views)
When I run the SVL Calibrate Microphone, there is no output from the calibrated sensor sensitivity?
How do I connect my micropone from the DAQ, do I select it as input or select as output. How do I calibrate it?
(4,705 Views)
(4,705 Views)
HI:
I'm doing the microphone sensitivity calibration vip, I have been given, what your problem solved?
(4,442 Views)
I saw that you posted your question on an old thread. In order to get more visibility, I would suggest creating a new thread with your question to get more chances to have an answer. Our forum community is rather active and this will allow you to have a faster answer. Hope this helps!
Best Regards
T. Le
Vision Product Support Engineer
(4,412 Views)
