Calculator
Hi, one help. I need to increase the execution speed of this program. I did a simple calculator with very basic funtions. I did this program with one local variable only. But still this program takes time 1 or 2 sec to get started. I need to know there is any other possibility to increase the speed and optimaze the code. I need to develop this program with more functionality. Read the instructions given in the front panel, before run this program.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
Message 1 of 9
(5,930 Views)
Hello.
I do not find that the program takes 1-2 seconds to start.
After pressing "run" I can immediately input numbers on the front panel.
Oksavik
Message 2 of 9
(5,922 Views)
But i got this delay sometimes, why?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 3 of 9
(5,919 Views)
Apart from this, any other optimization technique needed to increase the speed?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 4 of 9
(5,908 Views)
did you check labview calculator video in youtube ?!
check this link there is some more viedo about calculator there
https://www.youtube.com/watch?v=LMShsJ2mBuM
Message 5 of 9
(5,904 Views)
Hey, buddy thanks for the video!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 6 of 9
(5,898 Views)
Message 7 of 9
(5,891 Views)
Really useful for me!.. Thank you so much from bottom of the heart!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 8 of 9
(5,883 Views)
I hope it solve your problem but for more link you can also
See this link as main link for solution of your problem
https://forums.ni.com/t5/Example-Code/LabVIEW-Calculator/ta-p/3996227
Message 9 of 9
(5,866 Views)
