Calculator question
HI guys!!
I use labview is a novice and i did a calculator program and it have some problem.
i dont know how to display digital in string when the program is running,
but it can display on the highlight execution.
i hope someone can teach me
i really want to learn labview.
btw
because this pracetice , so it look very confused.
thank you.
(3,273 Views)
Hope you are new to LabVIEW, It better not to use sequence structure unnecessarily, go through the basics of labVIEW and Design Patterns (Probably simple state Machine Architecture)
(3,266 Views)
Hi Lapig,
Welcome to the forums and LV. Your code has a polling style architecture with sequence structures, the reason we recommend going for a state machine over sequence structures is so it can be responsive, reconfigurable, adaptable and scalable. It is a lot harder to do this with stacked sequences.
As a calculator has a lot of user interactions I'd also recommend using a event structure. You could start revising your code by looking into event structures and making a simple VI with a single while loop and single event structure.
LV Environment Tutorials:
http://www.ni.com/getting-started/labview-basics/environment
Design patterns for LV
ftp://ftp.ni.com/pub/branches/uk/stfc/Best_Practice_for_Block_Diagrams_and_Front_Panels.pdf
Hope this helps.
Pete
Certified LabVIEW Architect
(3,246 Views)
