Calculation
Hello
I am a new user of LabView (2018) and I have an assignment to do but I cannot work it out. I have to work out the total surface area and volume of a few shapes. If anyone could help me out by showing me an example of a shape e.g. total surface area and volume of a cylinder or cone or pyramid. I would be so grateful.
Message 1 of 8
(6,045 Views)
Hi Haneen,
Why can't you?
Don't you have books on geometry in a library next to you?
Can't you use a search engine of your choice to find the formulas you need?
Example formulas for a cylinder…
Message 2 of 8
(6,032 Views)
I do have the formulas for all the shapes that are needed but we have to create a VI on labview that must work with any numbers entered
Message 3 of 8
(6,010 Views)
Hi Haneen,
And what is your problem?
What have you tried?
Where are you stuck?
Why don't you attach your current VI? (Please save a down-converted version in LV2014 (edit menu -> save for previous…) and attach that to your message.)
Message 4 of 8
(6,002 Views)
I didn’t save the VI that wasn’t working but I can attach the question
Message 5 of 8
(5,997 Views)
Hi Haneen,
Then recreate the VI from scratch!
We will not do your homework…
Those are very basic questions.
And you surely can solve them after taking the beginner courses offered in the "Training" section in the header of this LabVIEW board!
You still don't answer the questions:
Message 6 of 8
(5,990 Views)
Well if you have the formulas then you just need to look closely at the Numeric palette for all of the standard arithmetic operators.
Also in the Structures palette you will find the "Formula Node", that could also be very useful to you...
=== Engineer Ambiguously ===
Message 7 of 8
(5,971 Views)
No, you have to create five VIs, one for each shape. Do one from scratch, ensure it works correctly, make copies, and do the others from the copies with minor changes. Since the inputs are lengths, I would limit the inputs to positive numbers (and maybe zero).
Assuming you don't have problems with the math, you seem to have problems wiring it up. Did you miss the first few classes? Maybe you can get the lecture notes from elsewhere. If all else fails, there are plenty of LabVIEW tutorials that can get you started. Look for the various links under "LabVIEW training resources" here.
See how far you get. Once you have a program and it does not work right, post it here and we will point you in the right direction.
Message 8 of 8
(5,959 Views)
