This widget could not be displayed.
Calculating within a for-loop
Hello!
I have an 2D array that i process within a for-loop. The array consist of two columns, one for the date/time stamp and one for the corresponding data measurements.
What I need to do is to loop through the array at one point at a time, and calculate the mean from time t to time t+n (n is a set value, i.e 10 min). I think i pretty much have got the code right, but I need some help to finish it.
The pseudo-code should look something simple as this:
for time t to time t+n
calculate mean
By the way, the time between the measurements is not fixed, so I need to use the time and not the number of datapoints.
Greetings
Kristoffer
Message 1 of 10
(4,666 Views)
Hi Kristoffer,
your pseudocode should look as simple as this:
for all items in array
   if time in range then add value to array2
next item in array
average array2
Message 2 of 10
(4,565 Views)
Thanks Gerd!
I was thinking that it might end up with something like that. May I ask if you have some example code or something? As I am having a bit of trouble with realizing the pseudo code..
Greetings
Kristoffer
Message 3 of 10
(4,559 Views)
Accepted by topic author Sjefsgjogleren
you should try something like this:
Rodéric L
Certified LabVIEW Architect
Message 4 of 10
(4,546 Views)
Thanks! Seemed to help me some way along the road!:)
Maybe I did not explaned the whole problem good enough.
I need to find the interval (of i.e. 10 min) with the lowest mean in my data. That means that i need to take time instance 0 (element 0 from the time/date column) and calculate the mean for the coming interval. Then I need to do the same for the next intervall and so on. To be able to find the lowest mean i guess all means should be saved to an array? It would also be easier to process the mean data later by doing that i guess?
Your code helped me a lot Rodèric, but I cant get it to work 100%. I seems like it doen't wont to update the mean continousley.
I have included my program as well as some test data, really really hoping that you or someone else can help me a bit further on this one!:)
Greetings
Kristoffer
Message 5 of 10
(4,538 Views)
Actually, think I solved it now! Thanks a lot for the help guys!:D
Greetings
Kristoffer
Message 6 of 10
(4,488 Views)
you're welcome
Rodéric L
Message 7 of 10
(4,428 Views)
Seems like I maybe was a bit fast on this one, as I am still struggeling to calculate the moving average. As I am only processing one data point to the mean.vi pr iteration the mean.vi just returns the same number as it gets in. Any suggestions on this one?:)
Greetings
Kristoffer
Message 8 of 10
(4,417 Views)
Hi Kristoffer,
I would suggest to calc the mean using more than just one value!Smiley Wink
I would also suggest attaching the current VI you're working on...
Message 9 of 10
(4,411 Views)
Hehe;) well, i kind of figured out that one, just could figure out how!:P
I have now attached a test dataset and the program;)
Message 10 of 10
(4,408 Views)
