Calculating Percentile
I am using Percentiles VI that comes with LabVIEW on my input array (see attached). I am however noticing some difference when I do the same percentile calculation using Microsoft Excel. Am I missing anything or doing something wrong in LabVIEW?
Thanks.
(5,115 Views)
You should not be suprised. You should not trust excel, when it comes to precision. I tried the same using MATLAB:
LabVIEW and MATLAB gives the same result. I suspect it is the formula excel uses to calculate the percentile.
But I will go with LabVIEW, especially since it is confirmed with MATLAB.
(5,084 Views)
Thanks for checking the numbers with Matlab. I will go ahead and use the percentile VIs for statistical computation.
I came across the Wiki page that mentioned about NIST standard that Excel uses (http://en.wikipedia.org/wiki/Percentile)
(5,078 Views)
Strange is that Open Office gives the same as Excel*
However it is noted that LabVIEW returns 84.95 for the  67th percentile.
The distribution of your data is a litle bit off:
Especially in the end you see large jumps.
Ton
* not so strange, OO wants to mimic excel as good as possible.
My LabVIEW Ideas
(5,077 Views)
