Calculate the mean after 2 seconds
Hello
I want to calculate the mean after 2 seconds when the graph basically increments. I do not want to calculate the whole  mean of the graph, only when it increases.
KJ
(1,867 Views)
Store 2 seconds worth of the data and then perform the mean on that data.
We need a lot more context (ie code) to make any more detailed recommendations.
(1,833 Views)
  • What graph?
  • What causes it to increment? (Also what's the meaning of "basically").
  • Is the data rate constant?
  • How many data points in two seconds?
  • What is the "whole mean"?
  • Do you mean an "increase" in x or in y? (is that related to the "increment" mentioned above?)
Typically you would just keep the sum in a shift register and divide by the count after each interval. No need to accumulate arrays. There is even a "mean ptbypt" that you could read and reset as required.
It would be so much easier for all of us if you would attach some simplified code. Thanks!
(1,814 Views)
