Calculate table average grouped by another field
Hi -
I am hoping to understand a simple way to calculate grouped summary stats from a table.  I'd like to calculate mean, standard deviation, and a number of quantiles (1%,2%, 5%, etc.) from a table.  I'd like these results to be grouped by other fields in the table.  I am providing a very simple example, but would like to be able to perform this calculation in an efficient way so that it works well for more complicated data sets.  My data sets have many grouped by terms and are not sorted by the grouping parameters.
In the example below, I'm showing how to calculate average values grouped by name.  I know I could sort them by name and look for changes in this parameter, then use those indeces to create subarrays and calculate averages from there.  I would prefer to use a function designed for this purpose like those available in SQL (minus the quantiles), JMP, and matlab.
Maybe the answer is use the mathscript function, but I've had issues with those mathscript windows being buggy in the past.
Is there a clean labview function which can perform these calculations?
Jennifer
Name Value Avg
John 0.537456 0.577731
John 0.91844
John 0.279187
John 0.758893
John 0.394678
Mary 0.007313 0.486202
Mary 0.935343
Mary 0.432797
Mary 0.569353
Message 1 of 10
(4,098 Views)
You can do some interesting things using Variant Attributes.
Message 2 of 10
(4,078 Views)
Crossrulz beat me to it but variant attributes seems like a good solution here, since you can define the attributes to be any datatype.  I'll have to remember this for my own use as well.
aputman
Message 3 of 10
(4,067 Views)
I get an error?
Message 4 of 10
(4,061 Views)
I think the first Get Attribute needs an array, not a single value.  Crossrulz has auto-indexing turned on for it but I think that was an oversight.
aputman
Message 5 of 10
(4,056 Views)
I had the empty array hooked to it, but then that for loop doesn't run and the mean/std/name arrays end up empty.
Message 6 of 10
(4,049 Views)
attached vi and example data set
Message 7 of 10
(4,048 Views)
Accepted by topic author DaveRines
Sorry, I can't open your VI but this is what I have for the first loop which stores the values into the variant.  Like I said, Crossrulz is the same as this except he has auto-indexing turned on for the empty array.  It should be turned off so that the datatype stored into the variant is an array.
aputman
Message 8 of 10
(4,031 Views)
Thanks all!  That worked.
Message 9 of 10
(4,026 Views)
Weird.  I specifically remember turning that autoindexing tunnel off.  Oh well.  We got there eventually.
Message 10 of 10
(4,014 Views)
