Calculate quantile for an array?
Is there a labview function which can calculate quantiles?
Like the matlab function quantile?
https://www.mathworks.com/help/stats/quantile.html?searchHighlight=quantile&s_tid=doc_srchtitle
(4,651 Views)
You probably could make one quickly. See how far you get....
(4,632 Views)
Try Mathematics->Prob and Stats->Percentiles
(4,611 Views)
Not exactly the same (input is in percent instead of fraction) and it does not do the interval thing if fraction is an integer >1, etc. Still the code of this subVI is visible and can be used as starting point. 😄
(4,595 Views)
To My Knowledge there is no exact function to do this, but hopefully there should be a way to do using some Math Functions. Share your Input and the Expected Output Using Quantile
(4,580 Views)
