Calculate maximum value of subarray while creating it using a case structure and shift registers
I have two 1D arrays that contain cyclical information (kind of like a sine wave).  One that contains information on position in degrees and another that contains torque.  I would like to calculate the maximum torque value each time the position is within a certain range (e.g. from 30-80 degrees).  The ranges are repeated - that's why it is cyclical.   I use the "in range" function, a case structure and shift registers to build a new array with values that fall within the range I specify - this was the easy part (see VI attached).  I'm struggling with a way to calculate a maximum value for each subarray formed when values are "in range".   Your help is much appreciated.
Message 1 of 11
(4,140 Views)
One way would be to keep track of the array indices when coming in/out of range.  Then, look at each one of those subsets and find the max value.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 2 of 11
(4,135 Views)
Something like this:  (Though, I'm sure there is a more elegant way)
Message 3 of 11
(4,133 Views)
I thought of that and can easily create another array with indicies that fall within range.  However, I could only generate a list of indicies and I'm not sure where they should start and stop to use in an index array or array subset.  I might be able to figure it out if I knew when the case was true the first time it was in range.
Message 4 of 11
(4,130 Views)
I just got your last post - I'll check it and see if it work.  Thanks a bunch.
Message 5 of 11
(4,126 Views)
Is the position array really this regular? You then could just reshape the torque array into a 2D array, one cycle per row and then autoindex, taking the subset max for each iteration.
Message 6 of 11
(4,118 Views)
Unfortunately, it's really not that regular where I could rely on it with confidence.
Message 7 of 11
(4,114 Views)
Accepted by topic author tmanini
vt92's solution worked!  I agree that there should be a simpler solution, but your's works just fine.  Many thanks.
Message 8 of 11
(4,108 Views)
Then please attach more typical data. Is there noise in the real position?
Message 9 of 11
(4,105 Views)
It's not really noise - it's more inconsistency.  So a position output can run: 20, 30, 40, 50, 60 etc.  OR, it could run: 21, 24, 32, 41, 44, 51, 59 etc. But, it is always cyclical.
Attached you will find a .csv file with the data arrays - I'm using POS (ANAT) degrees column (column D if you open in excel).  There you also see torque in ft-lbs along with some other information.
Message 10 of 11
(4,101 Views)
