CVI Question - X axis scale
I know this is a basic question but I am unable to figure it out. I
want to scale the x axis of a plot. I am using plot waveform and
printing out the spectrum of a signal. I wish to change the x axis from
cycles per second to cycles per minute but am unable to find a
solution. I have tried changeing the x increment property in the
PlotWaveform function call but this does not work. Am I correct with
the x axis increment property and just missing something or is there
another way of doing this.
Ed Manlove
ecm@dspcon.com
(2,819 Views)
You can change the X scale
In the block diagram, creat "Property Node" of your plot , and then change
the property to
(X-scale--> Offset and Multiplier --> Multiplier ).
Then multiply the number you want.
Is it right answer in your question?
"Alfred Brower" wrote in message
news:3A51F1D6.82ABB241@dspcon.com...
> Ed Manlove
> ecm@dspcon.com
(2,819 Views)
