CVI/8.0.1 run time error
HI,
    When am trying to open labView8.2,before that NI labWindows/CVI 8.0.1 is coimng.How to avoid this?
With Regards
DS
(2,923 Views)
plz gv a sloution
(2,922 Views)
Are you trying to say that when you attempt to open LabVIEW, it actually opens LabWindows-CVI instead?
Are you using a shortcut or a selection from the Start Menu > All Programs > National Instruments > LabVIEW 8.2 > LabVIEW ?
Or are you using some other shortcut?  If a shortcut, did you create the shortcut?  If so, what application is it pointing to?
(2,900 Views)
