04-13-2012 07:57 AM
I'm trying to execute C-F and C-V sweeps using an HP 4192A impedance analyzer.
The trouble is that the values of display B are being acquired always with the value 0 (zero) although in the real screen the value is different from zero.
I would like to know if anyone already used the NI driver (HP4192A Measure.vi) in attachment as it is, and if it worked fine.
Tânia
04-16-2012 07:35 AM
Hi TIBraz,
As you can see on this link, this driver isn't supported or certified by NI so that means that this driver isn't very secure to use.
I recommend to use low level functions (NI VISA) to use your instruments, even if it's more plodding.
Sincerely
