09-30-2019 01:10 PM
Does anyone know how to communicate with an absolute position RS485 encoder through USB rather than a PXI or other DIO? I have a CUI AMT 21 and my advisor ordered the USB cable and not the 6pin so I can setup the encoder via AMT Viewpoint but am not sure if it's possible to view position data in labview through the USB without the AMT interface.
09-30-2019 02:47 PM - edited 09-30-2019 02:48 PM
Hi crayon,
at the website of the manufacturer of those AMT21 encoders you find a manual with all needed information about the communication protocol.
You need to read it, then you can create your VIs to communicate with this sensor.
03-31-2021 02:39 AM
Hello signedcrayon, were you able to communicate with the encoder? I already read the manual to understand the commands and the data rate, but the encoder is not responding. I also verified with the AMT Viewpoint that it is connected correctly.
I'm trying to communicate using the LabVIEW VISA functions sending strings constants (x54) with the Hex Display enabled.
