.CSV file reading
          I know this question was asked many times but I done everything write to read the .CSV file into labview. Though I was reading only first coloum and also it is not reading the exact value. It rounding the value to near integer. I checked all settings in data representation but don't have luck. Can some one help me.
(3,515 Views)
Did you even bother to look at the file or the help for the function? It's not a csv file at all. The delimiter is a ; and you have to specify that.
(3,506 Views)
Accepted by topic author shjukheter
Your "CSV" file contains a semicolon as the field separator.
Your VI uses the default separator when reading the file. The default is a <tab> character. You also index the same column twice.
See attached to see how to load the file you supplied..
(3,503 Views)
