CRIO will not detecting module and will not allow formating
We have the CRIO plugged in correctly and the lights light up showing that the it is getting power but the CRIO is not detecting the module and will not allow us to format the CRIO. We have also checked to make sure to check that the CRIO is clean. Please help us find a solution.
(2,725 Views)
Hey stesal,
Take a look at this webpage which has a lot of documentation on how to set up your cRIO and talk to the modules.
Connect and Set Up Hardware
http://www.ni.com/getting-started/set-up-hardware/
Check under the NI CompactRIO section for a list of troubleshooting steps.  This should get you going in the right direction.
Taylor
(2,670 Views)
