01-11-2008 02:58 PM
01-14-2008
11:27 AM
- last edited on
05-02-2025
10:30 AM
by
Content Cleaner
Hi Tim C.
Thanks for posting to the NI Discussion Forum. Since it sounds like you want to broadcast over the network without an established client connection, I would suggest UDP Multicast. If you want to establish a lossless connection for your communication, then I would suggest a TCP connection instead. See the following links for more information on UDP and TCP. If you decide to use UDP Multicast, I would suggest taking a look at the "UDP Multicast Sender.vi" and "UDP Multicast Receiver.vi" examples found in the NI Example Finder by searching UDP.
When to Use UDP Instead of TCP
Using LabVIEW with TCP/IP and UDP
If you'd like the user to view the status of your cRIO via Remote Front Panels, I would suggest looking over the following links.
How Do I Create a Remote Front Panel for Use on a Real-Time Target Executable?
Why Does My Remote Front Panel Indicator or Control Not Update?
Thanks Tim and I hope this helps!
02-01-2008
02:15 PM
- last edited on
05-02-2025
10:30 AM
by
Content Cleaner
Hello all,
While Mike's recommendations are good for Windows-based systems, LabVIEW Real-Time does not support UDP Multicasting. As mentioned in the KnowledgeBase, UDP Broadcast is a suitable alternative.
I apologize for any inconvenience this mixup has caused.
Cheers.
02-04-2008 09:05 AM
If the CRIO that I want to braodcast the UDP message is behind a router is it still possible to use UDP broadcast? F.Y.I. The CRIO does have a default gateway set in it's max configuration. And the CRIO web page is visable by laptops on the other side of the router.
So if the laptops can see the web page can they recieve a UDP message?
Tim C.
02-06-2008 06:39 AM
