CRIO Array to Analog Output
Hello everyone,
I am working with CRIO9074 (mcu side) with the block below I transfer the data  (from lvm file) consisting of "variable and voltage columns" to both the array and the graph with 1 millisecond intervals.
However, when I want to take the data from the array and transfer it to the CRIO analog output, the software cycle slows down a lot. How should I do this?
Best regards..
Message 1 of 8
(1,368 Views)
Is your VI running on the host PC or cRIO? Can you upload your entire project?
https://tmesystems.net/
Message 2 of 8
(1,337 Views)
Hi btncan,
@btncan wrote:
I am working with CRIO9074 (mcu side) ..
  • What do you mean by "slows down a lot"? What exactly is "a lot"?
  • You use the ScanEngine: what is the sample time of the ScanEngine? (You know the 9074 is very old and slow when using the ScanEngine?)
  • Why do you need all those local variables?
  • Why do you need a 1MHz timed loop?
  • Why do you use a XYGraph on a headless (aka does not support a monitor!) cRIO?
  • Why do you access the file twice?
Message 3 of 8
(1,326 Views)
The project is running in CRIO and the file reading is done from the "C:\" drive in 9074.
There was no problem reading the data and transferring it to the array.
I will upload it below.
Message 4 of 8
(1,308 Views)
Hi GerdW,
*I set the loop speed to 1ms, after file transfer it becomes 17ms. I used "pi" controller as controller. The original version was in the project file.
*Iam currently working at 1ms cycle speed (the setting in the picture has been changed), I am also working on the FPGA side (25uS) but I wanted to work on the mcu side first.
*Should I stop the local variables to increase speed?
*I am currently doing 1ms cycling (adjusted setting in the picture)
*I don't fully understand
I have attached the project file
Thank you for your help.
Message 5 of 8
(1,305 Views)
Hi btncan,
You didn't attach the "project file", but only one VI…
Your whole VI could fit on y FullHD screen:
Just because you define a loop rate doesn't mean the code inside could be execute as fast as you like to…
How long does the ScanEngine need to read your AI and write the AO?
  • You don't need local variables once you use more wires and less sequence frames!
  • Your cRIO doesn't support any frontpanels displayed on a monitor, so you don't need any charts/graphs in the VI…
  • You call ReadDelimitedSpreadsheetFile twice in the first frame, but only use the putput of one call. Why?
Message 6 of 8
(1,284 Views)
I edited the software as follows and limited the size of the read data to 1 second (1000mS), but unfortunately the main loop operating speed is over 1ms.
Message 7 of 8
(1,241 Views)
You want to start debugging and find out which part of your code is slowing down.
The first thing I would check is your subVI. You can use VI Profiler to monitor the execution time.
What's the execution setting of your Derivative SubVI? You might want to try setting it to subroutine to minimize the overhead. See VI Execution Speed
Message 8 of 8
(1,230 Views)
