CRI
I'm using a NI 9025 cRIO and on slot1-slot4 I have two NI9225 and two NI9227 modules. I'm using the CRI to detect the modules on the chassis (NI9118). But when I'm running the code the "cRIO Module Info" returns "No Module" for slot1-slot4. But when I plug the module out and plug it in, the module is detected. I'd appreciate if anyone could help.
(3,722 Views)
Hi Gevorg,
I am not able to see the picture you posted in your message, could you add it as an attachment instead? In addition, I was looking at the compactRIO Information tutorial (http://zone.ni.com/devzone/cda/epd/p/id/1717) and found that the NI 9118 chassis is not supported by the reference library which would be why you are running into module identification problems.
Aldo A
(3,693 Views)
Hi Aldo A,
Thank you for your response. I attached the picture. Actually this mechanism works for the other modules (on NI9118 chassis), but for the NI9225/9227 it doesn't work properly.
(3,683 Views)
Hi Gevorg,
Do you have another chassis you can swap so you can test if the modules behave the same way?  That will help us narrow your issue down to either the modules or the program.
Aldo A
(3,667 Views)
Ok I'll try it with an other chassis. Thank you
(3,653 Views)
