CREATING RANDOM ELEMENTS
THE MAGIC TEXT INTIALIZED AS ABCD,AND I HAVE TO CREATE 50 RANDOM ELEMENTS FROM THAT TEXT..CAN ANYONE HELP ME
Message 1 of 35
(10,147 Views)
FIRST TURN OFF YOUR CAPS LOCK KEY.  CAPS LOCK BLOCKS MAGIC.
There, that is better.
Now describe your problem in a way we can understand.  What is "magic text"?  What do you mean by "ABCD"?
Post some examples of what you have and what you are looking for.
Message 2 of 35
(10,135 Views)
If the file does not exist, the Magic Text is initialized to a random sequence of 50 capital letters from the latin characters “ABCD” (e.g., “BDACCCBABADBDABDA...”).
Message 3 of 35
(10,129 Views)
I want to know how to generate 50 random latin characters.
Message 4 of 35
(10,126 Views)
Do a search for random number on your functions palette and go from there.
Bill
CLD
(Mid-Level minion.)
Message 5 of 35
(10,120 Views)
Look in your string palette.  There are VIs like String Subset and Index String Array you can use to pick a random (random is in the Numeric palette) element from a string.  Then just put it in a for loop and loop 50 times to concatenate a random string of your elements.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 35
(10,114 Views)
no ,i didnt find solution from your answer ,i dont want random characters,i just want ABCD letters bcddadd.....=50.
Message 7 of 35
(10,102 Views)
i dont want to run n=50,i jst want  50 capital letters from abcd
Message 8 of 35
(10,093 Views)
You should be able to do what you need to do with the information we gave you - IF you are actually trying to solve the issue and not just hoping someone does it for you.
THINK... random number from 1-4 in a loop that executes 50 times...  There, I've gotten you started...
Bill
CLD
(Mid-Level minion.)
Message 9 of 35
(10,087 Views)
Generate a random number from 0 to 3.  Then use Array Index to pick your letter (A, B,C, and D stored in an array of strings).  Use autoindexing to create an array of strings for your characters.  You can then use Concatinate Strings to turn it all into a single string.
Message 10 of 35
(10,083 Views)
