CRC-16 with 0x8005 polynomial
I am not getting the expect result. I modified the VI to look like this:
Message 11 of 22
(5,927 Views)
Could you post a picture of your modified version?
Message 12 of 22
(5,915 Views)
The 0x1FF3 should be 0x4042...
Message 13 of 22
(5,912 Views)
Accepted by topic author swbpnole
Here, use this.
Message 14 of 22
(5,906 Views)
Could explain this one? Why the changes?
Message 15 of 22
(5,901 Views)
This VI is based on a setup I have had for a very long time.  Like I said before, there are many different ways to do a CRC.  In this case, we needed to shift the CRC to the left while the Data is shifted to the left.
Message 16 of 22
(5,893 Views)
Are you using a PC? This is too wierd I am not getting this...Smiley Sad
Message 17 of 22
(5,887 Views)
Mine:
Message 18 of 22
(5,873 Views)
Try right-clicking on the Boolean Array To Number and select properties.  There is a tab in there to allow you to change the output data type.  Change that to a U16.  I'm not seeing anything else obviously wrong.
Message 19 of 22
(5,855 Views)
Between you and the NI AE, I realized it was my polynomial and initial value representations, both were I32 and should have been U16. Thanks...
Message 20 of 22
(5,843 Views)
