CPU problem while using Transport Delay in Simulation Loop
Hi
When I use the Transport Delay block in the Simulation Loop, the CPU is increasing till it finally goes to 100% CPU usage after a while.
Do I have to make sure that the Transport Delay block gets to finish before next timestep of the simulation loop?
I observed that the VI time for the Transport delay Distributor core is increasing while the program is running.
What can i do to make sure that this does not increase?
It has crossed my mind that the Configuration Parameters of the Simulation Loop may be wrong. What is important when I choose values for the different parameters?
Thanks for the answers
Morten
(2,666 Views)
Morten,
A Simulation loop (as well as a conventional While loop) will typically run as fast as possible until a simulation is complete.  This will take 100% CPU usage, unless you configure the timing parameters of the loop to run at a specific rate.  I'm not sure what you mean when you say that the VI time for the Transport Delay Distributor core is increasing.  If you could post your Simulation VI, I can take a look at it and possibly give suggestions on how to best configure it.  The ideal Simulation parameters are specific to what sort of system you are trying to simulate, so I cannot say more without knowing more about what you are trying to do.
Chris M
(2,654 Views)
