CPU performance monitor?
I'd like to write a module which displays CPU and memory usage to the user similar to what is visible in the task manager / performance monitor window. I have found >>>this<<< article which is cool, but not quite what I need. See the chart below:
My PC has 4 cores with 2 logical cores each, so I put 8 graphs on the chart each representing the load of a given logical processor. Then (at about the middle) I launched a VI which has nothing but a while loop with a false constant at its conditional terminal.
In the task manager I saw what I expected: one of the cores got compeletely busy with the VI so the CPU load increased to about 25% and stayed there (I didnt have any other load on the CPUs except this VI so 25-26% looks good). In my VI though the logical cores went up and down and it was not even that a given core take the full load, but it seems the task changed cores. I dont know if this is possible at all, I'm not an expert on this subject, but this is what my graph suggests.
What I have in my VI could have more details, but for me and for a regular user is a lot less informative, so I'm wondering if there is a way to get values diplayed by the task manager directly?
(Using Windows11. I took a sample from the CPU load in every 1000ms and displaying the average of the last four samples)
Thanks.
Message 1 of 17
(3,087 Views)
I using pdh.dll to obtain these counters:
and they matched Task Manager values (more or less, you might need to have some minor averaging and rescaling to get 1:1 visual appearance):
Andrey.
Message 2 of 17
(3,061 Views)
Could you convert this back to LV2022?
Message 3 of 17
(3,055 Views)
Yes, sure, downgraded to LV2022 in attachment.
Message 4 of 17
(3,042 Views)
you can get the taskmanager values via windows' perfmon.exe, which is part of Windows 11
perfmon can also be used to create a logfile
but the whole .exe is sort of clumsy to use.
a good soul wrote this dot net wrapper for LabView, which I tested with LabView 2020 64bit and Windows 10
https://forums.ni.com/t5/Example-Code/Performance-Monitor-Using-LabVIEW/ta-p/3501988
Message 5 of 17
(3,036 Views)
Hi Andrey,
what about a VI version for the pre-subscription era?
Could you downconvert to LV2019 or LV2021?
Thanks!
Message 6 of 17
(3,010 Views)
@GerdW wrote:
Hi Andrey,
Thanks!
You're welcome! Attached in LabVIEW 2018. That was an issue with 32-bit, because 64 bit was hard coded, but now should work for both 32-bit and 64-bit LabVIEW.
In general its doesn't matter how performance counters are obtained, in theory the .net - based solution should output exactly the same measurements. But usually if a have a choice to stay dependent from pure DLL or .net assembly, then I choosing DLL (in the past got some troubles with very old code and .net).
On the other hand, on Windows 11 I have seen some strange differences in term of CPU load and memory usage appeared in Task Manager compared to other tools like SysInternals.
Andrey.
Message 7 of 17
(2,976 Views)
Hi Andrey,
thanks for your effort, but with LV2021/32bit on Win11Pro22H2 I don't get any useful CPU load data, just "zero" load for all cores.
I have to investigate that behaviour when I have some more time…
Message 8 of 17
(2,943 Views)
Hey Andrey. Actually same here, your code does not work on my PC (win11). The dll call throws an error even if I browse the dll and add it to the call library node.
Message 9 of 17
(2,939 Views)
@GerdW wrote:
Hi Andrey,
Ah, its because you're under non-English OS with very big probability. For example, for German it should be "\\Prozessor(%d)\\Prozessorzeit (%%)" instead of "\\Processor(%d)\\%% Processor Time". Or, better, to use language neutral PdhAddEnglishCounterA() function. Good to know, thank you.
Try attached one, probably should work for you:
Message 10 of 17
(2,911 Views)
