CPU Usage
Hi guys!
I would like to know if its possible get CPU usage from a VI while running(exe in a future)
Thanks.
(2,474 Views)
Hi Ivan,
Do you want the CPU load of a single VI or the whole program?
Getting the CPU load of the whole program is possible using Windows function calls…
(2,471 Views)
Hi Gerd,
@GerdW  ha escrito:
Hi Ivan,
Whole program. I tried with function calls but i haven't found out. If you can help me i appreciate so much.
(2,446 Views)
Hi Ivan,
when using my favorite search engine for "labview cpu usage" I find a lot of websites discussing your problem, like this or that one…
(2,419 Views)
If you want to be system independent (.Net only works on Windows) you can use the NI System Control API. An example showing how this works would be at <LabVIEW>\examples\nisyscfg\Resource Monitor.vi
Rolf Kalbermatter  My Blog
(2,405 Views)
@GerdW  ha escrito:
Hi Ivan,
Thank you Gerd, I'm gonna check!
(2,305 Views)
@rolfk  ha escrito:
thank you mate!
(2,304 Views)
