05-07-2020 11:17 AM
I'm trying to monitor CPU Load using system Configuration tools. I've two computers, this code works well on one PC but the other one generates error.
05-07-2020 11:29 AM
What versions of the operating systems are running on both? What is the model and type for each computer. Could be that you need to update something on the computer that is failing. Perhaps a bios update.
05-07-2020 01:29 PM
Hi, Thanks for replying.
I'm using windows 7 Pro on both system. Having same version of LabView, i.e LabView 2019.
Systems are NI PXIe-8880. The system in which I'm facing the issue doesn't shows cores information in NI Max.
I am sharing NI Max snapshot for both PC's.
