CPU Load at RT Loop varies every time
I have a simple CAN Read Node in a RT Loop which runs on an sbRIO.
The CPU Load is at about 5-10%.
When I stop the VI and start it again, it sometimes goes up to 90% on one core.
Has anyone ever had such a problem?
(2,913 Views)
you have to put a sleep (with for example 250ms) somewhere into the while loop, please take a look into the attached image.
(2,859 Views)
Hi Kevin,
This is a Timed Loop. The delay is set in the loop Settings.
(2,845 Views)
Although this is a timed loop, I think you need to sleep for a while.
I can't explain why, but for me it mostly fixes this problem
(2,814 Views)
Hi nicolaus33,
are you still struggling with this issue?
If so, could you please write a little bit more about your project or perhaps share it? What is the part number of your sbRIO? Why are you using 1 MHz timed loop to read data from CAN? What does your application in general and what does this loop do in the context of whole project?
(2,762 Views)
Hi Agnes,
I get CAN Messages down to every 8ms and because you can only read one message at a time with the sbRIO CAN function, I need to use this fast cycle time.
(2,707 Views)
