CPP error line 638
Hi I'm having problems with the CPP ERROR at line 638, my application includes profibus and vision.  In the past when I had CPP ERRORS I had found if I sequenced the profibus VI this would eliminate the problem, however the problem has returned.  I thought maybe it would be the IMAQ for the vision, so  I bypassed the vision altogether, it is still in the code but not currently called or used. This hasn't helped either,  I was wondering if the issue could be with too many VI's running at the same time, perhaps a memory allocation problem, but I don't know at this point.
This has been most frustrating I'm running out of I deals  Smiley Sad
Jeffery Orn
(2,743 Views)
Hello Colorado,
Normally when you are starting up LabVIEW after a crash or another error happens, LabVIEW will give you the cpp file name and the line number.  You then have the option to investigate the error.  This will send a report to NI so that we can work on finding why the error happens and what we can do to fix it.  You should probably send that error to NI if you have not done so already.
Since the cpp file and the version of LabVIEW is missing from you post, you may want to include it.  It would probably be helpful to others who may have run into this error.
I hope this helps.
Steven T.
(2,724 Views)
