COPY PASTE ONE LV TO ANOTHER LV
I have TWO LV. Let's say LV-A and LV-B. They are similar but different. I want to DELETE ONE frame from LV-A and COPY ONE frame from LV-B. Can the frame I COPY from LV-B be PASTED on the DELETED frame from LV-A ? Is that POSSIBLE or do I have to DRAW the entire thing?
(3,460 Views)
You can only copy the image and, as you already know, you can only save one version backwords.
Message Edited by tst on 04-26-2005 07:04 PM
___________________
Try to take over the world!
(3,455 Views)
As far as I can tell, copying and cutting in LabVIEW place the object copied or cut onto two separate clip-boards. If you then paste the object back into the SAME LabVIEW process, you use LabVIEW's clip-board and it pastes the object. If you instead past the object into ANYTHING ELSE, like a second LabVIEW process (different version, etc.) it pastes off of the system clip-board and pastes an image of the object. It also works this way if you have something on the clip-board and crash LabVIEW. When you reopen LabVIEW, you can only paste an image, not the objects, since it is a different LabVIEW process.
By the way, this is one way to really mess with your co-workers: paste some code images onto the diagram and ask for help debugging!
Bob
(3,446 Views)
I like to mess with my co-workers, great idea Bob Y. I once had a screen saver that looked like the infamous NT blue screen of death. Sure got a good laugh when I showed my co-workers that I could "recover" by banging my fist on the desk (made the mouse move which made the screen saver go away).
- tbob
Inventor of the WORM Global
(3,442 Views)
If the two VIs are of the same version of LabVIEW, then yes, you can copy. Refer to the on-line help (copying> objects). When you say frame, I'm assuming you mean a frame of a sequence structure. Adding and deleting frames is also covered in the on-line help (Sequence Structures>adding frames).
(3,441 Views)
When I try to Copy a FRAME from LV-A and PASTE it on LV-B. I get the word HELLO! appearing. I use COPY & PASTE FROM EDIT MENU. If I use the other method it just PASTE as a picture and I canot use it.
(3,417 Views)
Did you first select the object(s) you want to copy? When selected, the object(s) should be surrounded with a dashed border. Are you sure you're copying between the same versions of LabVIEW. You're again struggling with some of the simplest techniques. These are techniques covered in the beginning of all LabVIEW classes. It seems to me that you could have taken several of the FREE on-line tutorials in the time it's taken for you to post these types of questions and gotten an answer back.
(3,401 Views)
