CONVERT NUMBER
Hi :
I have number in HEX which is FF78 , if i convert this number using calculator the number will be -136
nots i need to sign attach see picture
how i can do the in labview
thanks
(3,990 Views)
I assume that the input is a hex formatted string. Try the following (select I16 representation for the default constant):
(3,986 Views)
Hi elyan,
so you have a number and want to convert that to a signed 16 bit integer?
It could be that easy:
(3,982 Views)
As you can see, your problem description is quite ambiguous.
The above could mean:
  • A numeric indicator set to hex display
  • A hexadecimal formatted string containing two characters (in the range of 0...F) per byte
  • A binary string set to hex display containing two (often nonpritable) characters
So please tell us exactly what you have and what you want. Some scenarios don't need any code at all.
(3,976 Views)
