CONVERT BASE 36 TO DECIMAL
Any Vi to CONVERT BASE 36 TO DECIMAL?
Message 1 of 10
(7,940 Views)
continue here
Message 2 of 10
(7,934 Views)
The other thread refers to here. To break the cycle, lets keep things here in this thread. 😄
Message 3 of 10
(7,919 Views)
How many base 36 digits (0..Z) do you have in each number?
Message 4 of 10
(7,916 Views)
Attached is a very basic conversion from Base 36 to Base 10 that I wrote.  It only takes uppercase letters for Base 36 digits (you can fix this if you need to).  There is no error checking that the Base 36 string makes any sense (you can add this if you want to).  It does not add conversion for decimal, only whole numbers (you can add this if you want to).  This vi is just meant to get you started.  I hope it helps.
Cheers
Message Edited by jmcbee on 06-19-2008 02:07 PM
Message 5 of 10
(7,903 Views)
Here's a quick example:
(Of course you would need to add error checking for unusual characters, for example.)
Message 6 of 10
(7,896 Views)
Here's a slight improvement that adds support for lowercase letters and check the input for validity (For example if there is an illegal character suchs as @ in the input).
It also eliminates all orange wires and operates fully on integers.
Message 7 of 10
(7,876 Views)
I know you want to roll your own, but if you want to check your work,
http://bitizer.com converts Base36 to binary, hex, decimal, and ASCII to
very high bit depth.
Message posted using http://www.talkaboutprogramming.com/group/comp.lang.labview/
More information at http://www.talkaboutprogramming.com/faq.html
Message 8 of 10
(7,825 Views)
Cheers
hi  dear ,
you post this code  Attachment Base 36.vi (20 KB)
can you explane how this code work  please
thank you
Message 9 of 10
(7,488 Views)
Here's the explanation:
The math behind the value is quite simpe: base^position, where the first position left of the decimal sign is 1.
Ton
Message Edited by TonP on 11-13-2008 08:21 AM
My LabVIEW Ideas
Message 10 of 10
(7,485 Views)
