COM Exception while using CWGraph controls
I am trying to use activeX controls(AxInterop.CWUIControlsLib.dll, AxInterop.CW3DGraphLib.dll) provided by NI in my sample application (wriiten in C#) but I am receiving COM exceptions after the activeX controls gets instantiated.
Has anyone encountered such a problem before. Any help will be highly appreciated
(3,366 Views)
Can you elaborate a lil bit?
(3,358 Views)
I am trying to migrate a vb6.0 project which is using a CWGraph control to C# application. The installation of the vb6.0 application also adds cw3dgrph.ocx ,cw3dgrph.ocx and cwanalysis.ocx controls in System32 folder and I am referencing the same control in the C# application and trying to access the CWGraph control (C# itself creates the wrapper for this ActiveX controls:AxInterop.CW3DGraphLib,AxInterop.CWUIControlsLib,etc).
When I enable the CLRExceptions from the Debug menu in Visual studio and run the code , an unhandled exception of type COMException occurs without any description about th exception(it displays Unknown Error). everything runs fine if I disable the CLRException from debug menu.
(3,340 Views)
